[petsc-dev] petsc release plan for march/2020
    Jed Brown
    jed at jedbrown.org
    Wed Mar 25 20:05:55 CDT 2020
Matthew Knepley <knepley at gmail.com> writes:
> On Wed, Mar 25, 2020 at 8:23 PM Satish Balay via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> > > - feature freeze: March 27 say 5PM EST
>> A reminder, feature freeze is in 2 days. I see the following MRs with
>> milestone: v3.13-release
>>     !2598    Add Sphinx docs and port Developers Manual
>>     !2614    Knepley/feature dm remove hybrid
>>     !2626    More support for not needing to set PETSC_DIR yet build with
>> PETSc, also...
>>     !2634    WIP: Balay/release 3.13 revert to dev
>>     !2554    Knepley/feature fe lagrange gll
> 2554 is not merging. I will change the target.
If Toby's branch also isn't merging, is there a stop-gap we can have?  Or is Toby's branch merging and the milestone is missing?
