[petsc-dev] petsc release plan for march/2020
    Jed Brown
    jed at jedbrown.org
    Wed Mar 25 20:33:45 CDT 2020
Matthew Knepley <knepley at gmail.com> writes:
>> > On Wed, Mar 25, 2020 at 8:23 PM Satish Balay via petsc-dev <
>> > petsc-dev at mcs.anl.gov> wrote:
>> >> > > - feature freeze: March 27 say 5PM EST
>> >> A reminder, feature freeze is in 2 days. I see the following MRs with
>> >> milestone: v3.13-release
>> >>     !2598    Add Sphinx docs and port Developers Manual
>> >>     !2614    Knepley/feature dm remove hybrid
>> >>     !2626    More support for not needing to set PETSC_DIR yet build
>> with
>> >> PETSc, also...
>> >>     !2634    WIP: Balay/release 3.13 revert to dev
>> >>     !2554    Knepley/feature fe lagrange gll
>> > 2554 is not merging. I will change the target.
>> If Toby's branch also isn't merging, is there a stop-gap we can have?  Or
>> is Toby's branch merging and the milestone is missing?
> This branch will not work because it requires fixes for DMForest which it
> will not get in time. Toby said he was very close on his branch.
Should its milestone be set?
https://gitlab.com/petsc/petsc/-/merge_requests/2399
