[petsc-dev] petsc release plan for march/2020
    Matthew Knepley
    knepley at gmail.com
    Wed Mar 25 19:58:27 CDT 2020
On Wed, Mar 25, 2020 at 8:23 PM Satish Balay via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> > > - feature freeze: March 27 say 5PM EST
> A reminder, feature freeze is in 2 days. I see the following MRs with
> milestone: v3.13-release
>     !2598    Add Sphinx docs and port Developers Manual
>     !2614    Knepley/feature dm remove hybrid
>     !2626    More support for not needing to set PETSC_DIR yet build with
> PETSc, also...
>     !2634    WIP: Balay/release 3.13 revert to dev
>     !2554    Knepley/feature fe lagrange gll
2554 is not merging. I will change the target.
    Matt
>     !2367    WIP: Add sample file that demonstrates use of CMake and
> pkg-config to build a PETSc application
> I'm hoping all v3.13-release MRs will complete testing and reviews
> (approvals) before the freeze.
> Thanks,
> Satish
> On Fri, 20 Mar 2020, Satish Balay via petsc-dev wrote:
> > An update:
> https://gitlab.com/petsc/petsc/-/merge_requests?milestone_title=v3.13-release
> > We have a week to go. And have about 47 MRs, with 12 marked as
> 'v3.13-release' milestone.
> > Likely the milestone is not correctly set for some MRs - if so - please
> update the MR.
> > And I see some MRs with significant code changes. Hopefully we can
> process them early [and not have large changes close to freeze date].
> > Satish
> > On Fri, 13 Mar 2020, Satish Balay via petsc-dev wrote:
> > > All,
> > > We are to make a petsc release by the end of March.
> > > For this release [3.13], will work with the following dates:
> > > - release: March 29
> > > Merges after freeze should contain only fixes that would normally be
> acceptable to maint workflow.
> > > I've changed the current milestone 'v3.13' to 'master' and created a
> new one 'v3.13-release'
> > > If you are working on a MR with the goal of merging before release -
> its best to use 'v3.13-release' tag with the MR.
> > > And it would be good to avoid merging large changes at the last
> minute. And not have merge requests stuck in need of reviews, testing and
> other necessary tasks.
> > > And I would think the testing/CI resources would get stressed in this
> timeframe - so it would be good to use them judiciously if possible.
> > > - if there are failures in stage-2 or 3 - and its no longer necessary
> to complete all the jobs - one can 'cancel' the pipeline.
> > > - if a fix needs to be tested - one can first test with only the
> failed jobs (if this is known) - before doing a full test pipeline. i.e:
> > >    - start pipeline
> > >    - immediately cancel the pipeline
> > >    - now toggle only the jobs that need to be run
> > >    - [on success of the selected jobs] if one wants to run the full
> pipeleine - click 'retry' - and the remaining canceled jobs should now get
> scheduled.
> > > thanks,
> > > Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200325/52b268f0/attachment.html>
