[petsc-dev] print statements in fortran interface functions
Mark Adams mfadams at lbl.gov
Mon Mar 16 22:01:48 CDT 2020
Thanks, I have verified that PetscPrint with an installed libs works as
expected on my Mac (on ex73f90t).
I'll keep looking on Cori.
ThanksMark
On Mon, Mar 16, 2020 at 10:37 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
wrote:
> May be an issue printing to STDOUT, HPC sometimes redirect STDOUT to some
> other log files. Maybe try redirecting your PetscInfo() or PetscPrintf()
> output to a file. For PetscInfo its just a filename after the info flag:
> ./yourCode -info somefile . As for the PetscPrintf you will have to change
> those calls in your src to PetscFPrintf().
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
> On Mar 16, 2020, at 9:26 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Mon, Mar 16, 2020 at 9:50 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
> wrote:
>> Hello Mark,
>> If you are using PetscInfo to print, PetscInfo requires that you pass
>> “-info” as a command line flag in order to print anything. Sounds simple
>> enough to miss, did you run your code with it? i.e. ./yourCode -info?
> Yea, I added -info.
>> For what its worth, PetscPrintf on PETSC_COMM_WORLD will always print but
>> only from proc 0. PetscSynchronizedPrintf prints from all in order. Might
>> be more useful for debugging than PetscInfo!
> Yea, I started with PetscPrintf. Started with WORLD then tried SELF. Still
> no output but I can step through the code and see the print statements, but
> nothing.
> This is on Cori/Haswell. I have now used printf on my Mac and it works. I
> did not do an install on my Mac, but I would not think that would matter...
> I should test that I suppose.
>> Best regards,
>> On Mar 16, 2020, at 7:54 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> I am trying to debug an application code that works with v3.7 but fails
>> with master. The code works for "normal" solvers but for a solver that uses
>> FieldSplit it fails. It looks like vectors are not getting created from
>> MatCreateVecs with a matrix that is a MatNest (I can't run the code).
>> I have put print statements in the interface files to try to see what is
>> going on but the print statements seem to disappear somehow. (I added the
>> same print statements in my installation of v3.7 to see what is different)
>> I was using PetscPrint and then found and example of a Fortran PetscInfo
>> and switched to that. I stepped through the code with DDT and see the print
>> statements but nothing goes to the output. I did this DDT stuff with
>> ex73f90t, which has a MatCreateNest.
>> I am completely baffled. Does anyone have any ideas?
>> Thanks,
>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200316/8aabf645/attachment.html>
