[petsc-dev] Understanding -log_summary with GPUs
Junchao Zhang
jczhang at mcs.anl.gov
Tue Mar 10 17:44:50 CDT 2020
Hi, Shri,
I don't understand either. But there are many invocations of VecAXPY etc.
Is it possible some are done on CPU? Attach a debugger and set a breakpoint
on VecAXPY_SeqCUDA to see if it gets a hit. If yes, then see why.
--Junchao Zhang
On Tue, Mar 10, 2020 at 2:44 PM Abhyankar, Shrirang G via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> Hello all,
> I need help in understanding the output from -log_summary for the GPU
> related columns. I am currently simply setting -vec_type seqcuda which I
> believe performs the vector operations on the GPU. With -vec_type seqcuda,
> I presumed all vector operations are being done on the GPU. So, only the
> GPU MFlops will be logged, and CPU MFlops will be zero. But, -log_summary
> reports Mflops for both CPU and GPU. I do not understand why Mflops are
> shown both for CPU and GPU?
> What is the meaning of the last column – percent flops on the GPU? For
> instance, some operations such as VecDot show 100 %F, while others like
> VecAXPY have less. What is the meaning of this?
> Any other general comments on these numbers?
> Let me know if you need more information.
> Thanks,
> Shri
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200310/77567773/attachment.html>
