[petsc-dev] Understanding -log_summary with GPUs
Abhyankar, Shrirang G
shrirang.abhyankar at pnnl.gov
Tue Mar 10 14:33:07 CDT 2020
Hello all,
I need help in understanding the output from -log_summary for the GPU related columns. I am currently simply setting -vec_type seqcuda which I believe performs the vector operations on the GPU. With -vec_type seqcuda, I presumed all vector operations are being done on the GPU. So, only the GPU MFlops will be logged, and CPU MFlops will be zero. But, -log_summary reports Mflops for both CPU and GPU. I do not understand why Mflops are shown both for CPU and GPU?
What is the meaning of the last column – percent flops on the GPU? For instance, some operations such as VecDot show 100 %F, while others like VecAXPY have less. What is the meaning of this?
Any other general comments on these numbers?
Let me know if you need more information.
Shri
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200310/e6fff8cc/attachment-0001.html>
Desc: opflow_newell_gpu.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200310/e6fff8cc/attachment-0001.obj>
