[petsc-dev] Understanding -log_summary with GPUs
    Richard Tran Mills
    rtmills at anl.gov
    Tue Mar 10 23:33:40 CDT 2020
Hi Shri,
Probably the best way to understand what is going on is to step through
things using a debugger, as Junchao suggests. VecAXPY does get used in a
lot of places, and maybe it is being called on some vectors that aren't
getting their type from the options database? Also, there are several
places where a vector gets "bound" to execute operations on the CPU
instead of the GPU (see VecBindToCPU()) either because we know that the
vector isn't going to be needed on the CPU for subsequent operations, or
because the size of the vector is too small for it to make sense to do
on the GPU because of kernel launch latency. When a vector is bound to
the CPU, operations with it will be counted in the CPU MFlops column.
It looks like you are actually getting decent GPU usage for your vector
operations. While VecAXPY is showing only 80% of operations on the GPU,
it's also accounting for less than one percent of the total flops. I see
100% GPU flops for the VecMAXPY that accounts for 13% of your flops.
Best regards,
Richard
On 3/10/20 3:44 PM, Junchao Zhang via petsc-dev wrote:
> Hi, Shri,
>   I don't understand either. But there are many invocations of VecAXPY
> etc. Is it possible some are done on CPU? Attach a debugger and set a
> breakpoint on VecAXPY_SeqCUDA to see if it gets a hit. If yes, then
> see why.
> --Junchao Zhang
> On Tue, Mar 10, 2020 at 2:44 PM Abhyankar, Shrirang G via petsc-dev
> <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
>     Hello all,
>       I need help in understanding the output from -log_summary for
>     the GPU related columns. I am currently simply setting -vec_type
>     seqcuda which I believe performs the vector operations on the GPU.
>     With -vec_type seqcuda, I presumed all vector operations are being
>     done on the GPU. So, only the GPU MFlops will be logged, and CPU
>     MFlops will be zero. But, -log_summary reports Mflops for both CPU
>     and GPU. I do not understand why Mflops are shown both for CPU and
>     GPU?
>     What is the meaning of the last column – percent flops on the GPU?
>     For instance, some operations such as VecDot show 100 %F, while
>     others like VecAXPY have less. What is the meaning of this?
>     Any other general comments on these numbers?
>     Let me know if you need more information.
>     Thanks,
>     Shri
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200310/70f4d82e/attachment.html>
