[petsc-dev] How do I see the gcov results?
    Junchao Zhang
    junchao.zhang at gmail.com
    Thu Jun 25 09:59:20 CDT 2020
No. That is the plan. Petsc's script gcov.py works correctly and we need to
move it to codecov.io.
--Junchao Zhang
On Thu, Jun 25, 2020 at 9:34 AM Aagaard, Brad T via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> Are you opposed to using codecov.io to compile the results and generate
> plots?
> Brad
> On 6/24/20, 4:17 PM, "petsc-dev on behalf of Scott Kruger" <
> petsc-dev-bounces at mcs.anl.gov on behalf of kruger at txcorp.com> wrote:
>     For more detail, Stage 4 of the pipeline ("analyze-pipeline") has all
> of
>     the gcov data and you can download it from the right side after
> clicking
>     "Download" from "Job Artifacts" tab.  This is handled by the
>     .gitlab-ci.yml file (search for gcov).
>     If someone knows how gcov outputs it's data and how to upgrade the
>     lib/petsc/bin/maint/gcov.py to read in the data as gitlab organizes it
>     and then output the html/figures, then we'd have it done (locally.  To
>     upload to wiki or other gitlab display would require more work on the
>     gitlab-ci.yml file).
>     I spent quite a few hours on it, and got stuck.  It requires
>     understanding gcov to a degree that was interfering with other
> priorities.
>     If someone has the knowledge or inclination, it's a good problem to
> solve.
>     Scott
>     On 6/24/20 2:39 PM, Satish Balay via petsc-dev wrote:
>     > Its not yet setup in the current CI
>     > Satish
>     > On Wed, 24 Jun 2020, Matthew Knepley wrote:
>     >> Thanks,
>     >>     Matt
>     Tech-X Corporation               kruger at txcorp.com
>     5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
>     Boulder, CO 80303                Fax:   (303) 448-7756
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200625/bd01ea14/attachment.html>
