[petsc-dev] How do I see the gcov results?
Matthew Knepley
knepley at gmail.com
Thu Jun 25 10:03:03 CDT 2020
On Thu, Jun 25, 2020 at 10:34 AM Aagaard, Brad T <baagaard at usgs.gov> wrote:
> Are you opposed to using codecov.io to compile the results and generate
> plots?
Satish, if you create a deploy token (
https://docs.gitlab.com/ee/user/project/deploy_tokens/), I will start the
codecov process.
Matt
> Brad
> On 6/24/20, 4:17 PM, "petsc-dev on behalf of Scott Kruger" <
> petsc-dev-bounces at mcs.anl.gov on behalf of kruger at txcorp.com> wrote:
> For more detail, Stage 4 of the pipeline ("analyze-pipeline") has all
> of
> the gcov data and you can download it from the right side after
> clicking
> "Download" from "Job Artifacts" tab. This is handled by the
> .gitlab-ci.yml file (search for gcov).
> If someone knows how gcov outputs it's data and how to upgrade the
> lib/petsc/bin/maint/gcov.py to read in the data as gitlab organizes it
> and then output the html/figures, then we'd have it done (locally. To
> upload to wiki or other gitlab display would require more work on the
> gitlab-ci.yml file).
> I spent quite a few hours on it, and got stuck. It requires
> understanding gcov to a degree that was interfering with other
> priorities.
> If someone has the knowledge or inclination, it's a good problem to
> solve.
> Scott
> On 6/24/20 2:39 PM, Satish Balay via petsc-dev wrote:
> > Its not yet setup in the current CI
> > Satish
> > On Wed, 24 Jun 2020, Matthew Knepley wrote:
> >> Thanks,
> >> Matt
> Tech-X Corporation kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
> Boulder, CO 80303 Fax: (303) 448-7756
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200625/be310795/attachment-0001.html>
