[petsc-dev] How do I see the gcov results?
    Aagaard, Brad T
    baagaard at usgs.gov
    Thu Jun 25 09:34:35 CDT 2020
Are you opposed to using codecov.io to compile the results and generate plots?
Brad
On 6/24/20, 4:17 PM, "petsc-dev on behalf of Scott Kruger" <petsc-dev-bounces at mcs.anl.gov on behalf of kruger at txcorp.com> wrote:
    For more detail, Stage 4 of the pipeline ("analyze-pipeline") has all of
    the gcov data and you can download it from the right side after clicking
    "Download" from "Job Artifacts" tab.  This is handled by the
    .gitlab-ci.yml file (search for gcov).
    If someone knows how gcov outputs it's data and how to upgrade the
    lib/petsc/bin/maint/gcov.py to read in the data as gitlab organizes it
    and then output the html/figures, then we'd have it done (locally.  To
    upload to wiki or other gitlab display would require more work on the
    gitlab-ci.yml file).
    I spent quite a few hours on it, and got stuck.  It requires
    understanding gcov to a degree that was interfering with other priorities.
    If someone has the knowledge or inclination, it's a good problem to solve.
    Scott
    On 6/24/20 2:39 PM, Satish Balay via petsc-dev wrote:
    > Its not yet setup in the current CI
    > Satish
    > On Wed, 24 Jun 2020, Matthew Knepley wrote:
    >> Thanks,
    >>     Matt
    Tech-X Corporation               kruger at txcorp.com
    5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
    Boulder, CO 80303                Fax:   (303) 448-7756
