[petsc-dev] How do I see the gcov results?
    Scott Kruger
    kruger at txcorp.com
    Wed Jun 24 17:16:42 CDT 2020
For more detail, Stage 4 of the pipeline ("analyze-pipeline") has all of
the gcov data and you can download it from the right side after clicking
"Download" from "Job Artifacts" tab.  This is handled by the
.gitlab-ci.yml file (search for gcov).
If someone knows how gcov outputs it's data and how to upgrade the
lib/petsc/bin/maint/gcov.py to read in the data as gitlab organizes it
and then output the html/figures, then we'd have it done (locally.  To
upload to wiki or other gitlab display would require more work on the
gitlab-ci.yml file).
I spent quite a few hours on it, and got stuck.  It requires
understanding gcov to a degree that was interfering with other priorities.
If someone has the knowledge or inclination, it's a good problem to solve.
Scott
On 6/24/20 2:39 PM, Satish Balay via petsc-dev wrote:
> Its not yet setup in the current CI
> Satish
> On Wed, 24 Jun 2020, Matthew Knepley wrote:
>> Thanks,
>>     Matt
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
