[petsc-dev] Getting .gitlab.ci file out of repository? https://docs.gitlab.com/ee/ci/pipelines/settings.html
    Jed Brown
    jed at jedbrown.org
    Tue Jun 23 00:19:48 CDT 2020
Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> say - you reorganized some configure code - and changed with-x to with-x11
> This means the corresponding change should also be config/*.py - for tests not to break. [but other branches would still have to use whats valid for them].
> So encoding examples/*.py a single/remote gitlab-ci.yaml just creates more problems
I thought Barry was just proposing inlining the configure options into .gitlab-ci.yml, which I think would work fine, but also don't clearly see a point.
> On Mon, 22 Jun 2020, Barry Smith wrote:
>>   I see, the way it is now each test case in the .gitlab file is hardwired to an examples/*.py maybe we should just delete the examples/*.py and put them directly in the yaml file.
