[petsc-dev] Getting .gitlab.ci file out of repository? https://docs.gitlab.com/ee/ci/pipelines/settings.html
Satish Balay
balay at mcs.anl.gov
Mon Jun 22 19:40:57 CDT 2020
say - you reorganized some configure code - and changed with-x to with-x11
This means the corresponding change should also be config/*.py - for tests not to break. [but other branches would still have to use whats valid for them].
So encoding examples/*.py a single/remote gitlab-ci.yaml just creates more problems
Satish
On Mon, 22 Jun 2020, Barry Smith wrote:
> I see, the way it is now each test case in the .gitlab file is hardwired to an examples/*.py maybe we should just delete the examples/*.py and put them directly in the yaml file.
> Barry
> > On Jun 22, 2020, at 7:01 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > An automatic message asking rebase was preferred over other issues we previously had.
> > And the examples/arch*.py are in sync with the sources [in branch] and .gitlab.ci is in sync with examples/arch*.py
> > And updates to any of them can be done in a feature branch [as feature changes result in CI changes] - and the merge propagates such changes nicely [and does force a rebase]
> > And if they are split up - then we'll have to worry about manually syncing them - can't really test changes before doing updates. [and worry about having a single config file that handles both maint and master.]
> > However - in some sense - the ability to modify .gitlab.ci in any feature branch is not a good thing..
> > Satish
> >> Should we get the .gitlab.ci yaml file out of the repository so people don't need to constantly monkey around with rebasing etc when something needs to change in the file?
> >> Seems to be number of ways of having out of the repository.
> >> What about the the examples/arch*.py files? Do we have to use the ones in the repository?
> >> Of course we should rebase against master or maint when testing but it gets annoying when you did do that but then immediately you have to do it again since some test machine when down. Shouldn't really be a concern of the developer when test machines go up and down.
> >> Barry
