[petsc-dev] Getting .gitlab.ci file out of repository? https://docs.gitlab.com/ee/ci/pipelines/settings.html
    Barry Smith
    bsmith at petsc.dev
    Tue Jun 23 08:27:05 CDT 2020
   The issue was when a machine went down we suddenly unknowningly had to rebase against some strange branch before running the pipeline. That was not a good work flow. Perhaps Satish fixed it so master and maint are adjusted when a machine goes down hence no strange branches to merge against.
   I do think a model that "just worked" when a machine went down without needing to change the .gitlab-ci file would be better.  If I remember vaguely can't every enry in .gitlab-ci be marked as "skip if the runner is not available". Can we adopt that model? We may have tried it before and were not happy with it?
   Barry
> On Jun 23, 2020, at 12:19 AM, Jed Brown <jed at jedbrown.org> wrote:
> Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>> say - you reorganized some configure code - and changed with-x to with-x11
>> This means the corresponding change should also be config/*.py - for tests not to break. [but other branches would still have to use whats valid for them].
>> So encoding examples/*.py a single/remote gitlab-ci.yaml just creates more problems
> I thought Barry was just proposing inlining the configure options into .gitlab-ci.yml, which I think would work fine, but also don't clearly see a point.
>> On Mon, 22 Jun 2020, Barry Smith wrote:
>>>  I see, the way it is now each test case in the .gitlab file is hardwired to an examples/*.py maybe we should just delete the examples/*.py and put them directly in the yaml file.
