[petsc-dev] gitlab CI pipleline issue with ps5
Satish Balay
balay at mcs.anl.gov
Sun Jun 21 16:45:22 CDT 2020
ps5 is now working [stable for the past few hours - and hopefully stays this way] - so I'm adding it back to CI [and reverting my prior change].
[So you would need to rebase over maint/master before starting any new test pipelines]
Satish
On Sat, 20 Jun 2020, Satish Balay via petsc-dev wrote:
> I pushed an updated version of this change to maint and master - so that CI gives more appropriate error [if using old snapshots]
> Will check on the broken box tomorrow. A reboot did not help - so its not clear if it can be easily brought back up. [and if we have to rely on this workaround for some time]
> Satish
> On Fri, 19 Jun 2020, Satish Balay via petsc-dev wrote:
> > All,
> > The machine ps5 (windows) is currently down, breaking CI. I'm not sure when it can be brought back up.
> > In the meantime - please use balay/ci-tmp-disable-ps5 to make progress. It disables the windows tests on ps5
> > [This branch can be merged or the corresponding commit cherrypicked into your feature branch for CI, and removed later]
> > Satish
