[petsc-dev] gitlab CI pipleline issue with ps5
Satish Balay
balay at mcs.anl.gov
Sat Jun 20 11:22:05 CDT 2020
I pushed an updated version of this change to maint and master - so that CI gives more appropriate error [if using old snapshots]
Will check on the broken box tomorrow. A reboot did not help - so its not clear if it can be easily brought back up. [and if we have to rely on this workaround for some time]
Satish
On Fri, 19 Jun 2020, Satish Balay via petsc-dev wrote:
> All,
> The machine ps5 (windows) is currently down, breaking CI. I'm not sure when it can be brought back up.
> In the meantime - please use balay/ci-tmp-disable-ps5 to make progress. It disables the windows tests on ps5
> [This branch can be merged or the corresponding commit cherrypicked into your feature branch for CI, and removed later]
> Satish
