[petsc-dev] "alt" versions of tests
Mark Adams mfadams at lbl.gov
Mon Jun 15 10:51:39 CDT 2020
src/ksp/ksp/tutorials/output/ex71_bddc_elast_both_approx_*alt.*out uses ML
and src/ksp/ksp/tutorials/output/ex71_bddc_elast_both_approx.out uses GAMG.
The test seems to look at the alt file and not the normal one. I don't
understand. I do get an error message ...
11:42 adams/cheby-spd-cg= ~/Codes/petsc-master$ make cleantest
/usr/bin/make  --no-print-directory -f gmakefile.test
PETSC_ARCH=arch-macosx-gnu-g PETSC_DIR=/Users/markadams/Codes/petsc
cleantest
/bin/rm -f -r ./arch-macosx-gnu-g/tests ./arch-macosx-gnu-g/tests/testfiles
11:42 adams/cheby-spd-cg= ~/Codes/petsc-master$ make -f gmakefile test
search='ksp_ksp_tutorials-ex71_bddc_elast_both%' PETSC_DIR=$PWD
*gmakefile.test:92: arch-macosx-gnu-g/tests/testfiles: No such file or
directory*/System/Library/Frameworks/Python.framework/Versions/2.7/Resources/Python.app/Contents/MacOS/Python
/Users/markadams/Codes/petsc-master/config/gmakegentest.py
--petsc-dir=/Users/markadams/Codes/petsc-master
--petsc-arch=arch-macosx-gnu-g --testdir=./arch-macosx-gnu-g/tests
Using MAKEFLAGS: PETSC_DIR=/Users/markadams/Codes/petsc-master
search=ksp_ksp_tutorials-ex71_bddc_elast_both%
          CC arch-macosx-gnu-g/tests/ksp/ksp/tutorials/ex71.o
     CLINKER arch-macosx-gnu-g/tests/ksp/ksp/tutorials/ex71
        TEST
arch-macosx-gnu-g/tests/counts/ksp_ksp_tutorials-ex71_bddc_elast_both_approx.counts
 ok ksp_ksp_tutorials-ex71_bddc_elast_both_approx
not ok diff-ksp_ksp_tutorials-ex71_bddc_elast_both_approx # Error code: 1
# 1,13c1
# <   0 KSP Residual norm 1615.07
# <   1 KSP Residual norm 420.868
# <   2 KSP Residual norm 187.45
# <   3 KSP Residual norm 67.3919
# <   4 KSP Residual norm 21.3237
# <   5 KSP Residual norm 5.8091
# <   6 KSP Residual norm 1.0923
# <   7 KSP Residual norm 0.527464
# <   8 KSP Residual norm 0.380684
# <   9 KSP Residual norm 0.0354163
# <  10 KSP Residual norm 0.0237308
# <  11 KSP Residual norm 0.0121289
# < Linear solve converged due to CONVERGED_RTOL iterations 11
# > Linear solve converged due to CONVERGED_RTOL iterations 10
# 77,92d64
# <     PC Object: 1 MPI processes
# <       type: shell
# <         Nullspace corrected interior solve
# <         L:
# <           Mat Object: 1 MPI processes
# <             type: seqdense
# <             rows=144, cols=6
# <             total: nonzeros=864, allocated nonzeros=864
# <             total number of mallocs used during MatSetValues calls=0
# <         K:
# <             type: seqdense
# <         inner preconditioner:
# 94,95c66,67
# <             type: ml
# <               type is MULTIPLICATIVE, levels=3 cycles=v
# >       type: gamg
# >         type is MULTIPLICATIVE, levels=2 cycles=v
# 97a70,77
On Mon, Jun 15, 2020 at 10:15 AM Satish Balay <balay at mcs.anl.gov> wrote:
> On Mon, 15 Jun 2020, Mark Adams wrote:
> > My pipeline is failing on ksp/ex71.c and it seems to be picking up an
> "alt"
> > version of the output.
> Hm - it does a diff with (basic, alt) files. If all diffs fail - then it
> prints a diff from one of them.
> > I tried REPLACE=1 and both output files seemed to
> > change. What is going on with these "alt" output files?
> I'm not sure how this works with alt files. I assumed it ignores alt
> files - and updates the primary file.  Usually I would need a new alt
> file - so I just move this over manually to a new one [and keep the
> current files unchanged]
> Note: To test the new alt file - one need to do 'make cleantest' and
> rerun the test - otherwise the test harness does not know that it
> should pick up the new alt file.
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200615/2478cff3/attachment.html>
