[petsc-dev] "alt" versions of tests
Scott Kruger
kruger at txcorp.com
Mon Jun 15 11:15:41 CDT 2020
This is more about how the reporting is done than one should interpret
what's actually happening under the hood. The way the test is formed is
essentially:
diff-test1 2> test.out || diff-test2 2> test.out
So diff-test1 output gets overwritten by diff-test2.
Let me see if I can fix.
Scott
On 6/15/20 9:51 AM, Mark Adams wrote:
> src/ksp/ksp/tutorials/output/ex71_bddc_elast_both_approx_*alt.*out uses
> ML and src/ksp/ksp/tutorials/output/ex71_bddc_elast_both_approx.out uses
> GAMG.
> The test seems to look at the alt file and not the normal one. I don't
> understand. I do get an error message ...
> 11:42 adams/cheby-spd-cg= ~/Codes/petsc-master$ make cleantest
> /usr/bin/make --no-print-directory -f gmakefile.test
> PETSC_ARCH=arch-macosx-gnu-g PETSC_DIR=/Users/markadams/Codes/petsc
> cleantest
> /bin/rm -f -r ./arch-macosx-gnu-g/tests ./arch-macosx-gnu-g/tests/testfiles
> 11:42 adams/cheby-spd-cg= ~/Codes/petsc-master$ make -f gmakefile test
> search='ksp_ksp_tutorials-ex71_bddc_elast_both%' PETSC_DIR=$PWD
> *gmakefile.test:92: arch-macosx-gnu-g/tests/testfiles: No such file or
> directory
> */System/Library/Frameworks/Python.framework/Versions/2.7/Resources/Python.app/Contents/MacOS/Python
> /Users/markadams/Codes/petsc-master/config/gmakegentest.py
> --petsc-dir=/Users/markadams/Codes/petsc-master
> --petsc-arch=arch-macosx-gnu-g --testdir=./arch-macosx-gnu-g/tests
> Using MAKEFLAGS: PETSC_DIR=/Users/markadams/Codes/petsc-master
> search=ksp_ksp_tutorials-ex71_bddc_elast_both%
> CC arch-macosx-gnu-g/tests/ksp/ksp/tutorials/ex71.o
> CLINKER arch-macosx-gnu-g/tests/ksp/ksp/tutorials/ex71
> TEST
> arch-macosx-gnu-g/tests/counts/ksp_ksp_tutorials-ex71_bddc_elast_both_approx.counts
> ok ksp_ksp_tutorials-ex71_bddc_elast_both_approx
> not ok diff-ksp_ksp_tutorials-ex71_bddc_elast_both_approx # Error code: 1
> # 1,13c1
> # < 0 KSP Residual norm 1615.07
> # < 1 KSP Residual norm 420.868
> # < 2 KSP Residual norm 187.45
> # < 3 KSP Residual norm 67.3919
> # < 4 KSP Residual norm 21.3237
> # < 5 KSP Residual norm 5.8091
> # < 6 KSP Residual norm 1.0923
> # < 7 KSP Residual norm 0.527464
> # < 8 KSP Residual norm 0.380684
> # < 9 KSP Residual norm 0.0354163
> # < 10 KSP Residual norm 0.0237308
> # < 11 KSP Residual norm 0.0121289
> # < Linear solve converged due to CONVERGED_RTOL iterations 11
> # > Linear solve converged due to CONVERGED_RTOL iterations 10
> # 77,92d64
> # < PC Object: 1 MPI processes
> # < type: shell
> # < Nullspace corrected interior solve
> # < L:
> # < Mat Object: 1 MPI processes
> # < type: seqdense
> # < rows=144, cols=6
> # < total: nonzeros=864, allocated nonzeros=864
> # < total number of mallocs used during MatSetValues calls=0
> # < K:
> # < type: seqdense
> # < inner preconditioner:
> # 94,95c66,67
> # < type: ml
> # < type is MULTIPLICATIVE, levels=3 cycles=v
> # > type: gamg
> # > type is MULTIPLICATIVE, levels=2 cycles=v
> # 97a70,77
> On Mon, Jun 15, 2020 at 10:15 AM Satish Balay <balay at mcs.anl.gov
> <mailto:balay at mcs.anl.gov>> wrote:
> On Mon, 15 Jun 2020, Mark Adams wrote:
> > My pipeline is failing on ksp/ex71.c and it seems to be picking
> up an "alt"
> > version of the output.
> Hm - it does a diff with (basic, alt) files. If all diffs fail -
> then it prints a diff from one of them.
> > I tried REPLACE=1 and both output files seemed to
> > change. What is going on with these "alt" output files?
> I'm not sure how this works with alt files. I assumed it ignores alt
> files - and updates the primary file. Usually I would need a new alt
> file - so I just move this over manually to a new one [and keep the
> current files unchanged]
> Note: To test the new alt file - one need to do 'make cleantest' and
> rerun the test - otherwise the test harness does not know that it
> should pick up the new alt file.
> Satish
Tech-X Corporation kruger at txcorp.com
5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
Boulder, CO 80303 Fax: (303) 448-7756
