[petsc-dev] PThread problem on CI
Matthew Knepley
knepley at gmail.com
Thu Jun 4 14:17:37 CDT 2020
On Thu, Jun 4, 2020 at 3:12 PM Satish Balay <balay at mcs.anl.gov> wrote:
> You can make this change - and test it by running this one test via CI
> [its same as me doing this manually]
Thanks! Will do it.
Matt
> i.e:
> - start the pipeline
> - cancel after pre stage
> - now toggle the one [or few tests] that you need to run.
> And I would think configure should have caught it.
> self.gitcommit = 'bcd82f996542f6d667ccf70a6d8644be1ef7a30f'
> self.download = ['git://
> https://github.com/bldenton/EGADSlite.git']
> self.functions = []
> Ok - no functions listed here - so configure is not doing any checks...
> Satish
> On Thu, 4 Jun 2020, Matthew Knepley wrote:
> > I have this problem:
> > https://gitlab.com/petsc/petsc/-/jobs/581886066
> > It's not strictly a CI problem, so I was asking here. The EGADS example
> > runs fine
> > for me on my Mac. It does use pthreads, so I guess on this machine I need
> > -lpthreads?
> > I cannot login to ANL anymore since they disabled my account. Can you
> check
> > that
> > -LIBS=-lpthread would fix it, and I will put a dependency in the
> configure?
> > Thanks,
> > Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200604/6dff4d46/attachment.html>
