[petsc-dev] Configure Downloads Wrong MUMPS
    Jacob Faibussowitsch
    jacob.fai at gmail.com
    Sat Jun  6 15:14:51 CDT 2020
Hello All,
As the title suggest configure downloads the wrong version of MUMPS (5.2.1) using —download-mumps even after —with-clean and manually rm -rf /petsc-arch/externalpackages/mumps_folder. The configure warning message says that 5.3 is the version that petsc is tested with. FWIW I am using MUMPS with slepc (but slepc is installed through petsc), so perhaps there is a version mismatch between what slepc and petsc expect?
 Trying to download https://bitbucket.org/petsc/pkg-mumps/get/v5.2.1-p2.tar.gz for MUMPS       ===============================================================================
Warning: Using version 5.2.1 of package mumps PETSc is tested with 5.3
Suggest using --download-mumps for a compatible MUMPS                                         ===============================================================================
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200606/83a59400/attachment-0002.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200606/83a59400/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200606/83a59400/attachment-0003.html>
