[petsc-dev] PThread problem on CI
Satish Balay
balay at mcs.anl.gov
Thu Jun 4 14:12:01 CDT 2020
You can make this change - and test it by running this one test via CI [its same as me doing this manually]
i.e:
- start the pipeline
- cancel after pre stage
- now toggle the one [or few tests] that you need to run.
And I would think configure should have caught it.
self.gitcommit = 'bcd82f996542f6d667ccf70a6d8644be1ef7a30f'
self.download = ['git://https://github.com/bldenton/EGADSlite.git']
self.functions = []
Ok - no functions listed here - so configure is not doing any checks...
Satish
On Thu, 4 Jun 2020, Matthew Knepley wrote:
> I have this problem:
> https://gitlab.com/petsc/petsc/-/jobs/581886066
> It's not strictly a CI problem, so I was asking here. The EGADS example
> runs fine
> for me on my Mac. It does use pthreads, so I guess on this machine I need
> -lpthreads?
> I cannot login to ANL anymore since they disabled my account. Can you check
> that
> -LIBS=-lpthread would fix it, and I will put a dependency in the configure?
> Thanks,
> Matt
