[petsc-dev] C++ error
    Mark Adams
    mfadams at lbl.gov
    Tue Jul 14 16:35:48 CDT 2020
On Tue, Jul 14, 2020 at 3:42 PM Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 14 Jul 2020, Mark Adams wrote:
> > > Just build with --with-single-library=0 --with-shared-libraries=0
> > FYI, that did not seem to work. But I think I figured it out (without too
> > many more runs).
> Hm - static build would give errors while compiling examples if
> PETSC_DM_LIB is used instead of PETSC_LIB in link line [and the associated
> function from DM is used by the example]
> shared builds give this error on Ubuntu - but not on fedora [don't know
> why]. And I don't know if OSX gives this error or not.
I am on OSX.
> BTW: With CI - you can start it, cancel it, and then re-run only selected
> jobs - so that unneeded jobs are avoided. [when debugging specific failures
> on specific jobs]
I did not see that. How do you select just one run? I can see how to rerun
it but it does not pull a new version AFAIK.
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200714/a1e8acb3/attachment.html>
