[petsc-dev] pipeline failure
Satish Balay
balay at mcs.anl.gov
Mon Jul 13 15:32:40 CDT 2020
At Matt alluded to - its a circular dependency - hence the error.
i.e DMPlexSNESComputeJacobianFEM() is a SNES function - so it can't be called from DM sources [src/dm/impls/plex/landau/plexland.c]
The dependency order is:
-lpetsctao -lpetscts -lpetscsnes -lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetscsys
Satish
On Mon, 13 Jul 2020, Mark Adams wrote:
> I did add #include <petscts.h> to petscdmplex.h. THat is all that I can see
> that could cause trouble.
> On Mon, Jul 13, 2020 at 4:11 PM Mark Adams <mfadams at lbl.gov> wrote:
> > THis error was in this one also, plus warnings:
> > https://gitlab.com/petsc/petsc/-/jobs/636537354
> > "/export/home/glci/builds/zxfiRCGf/0/petsc/petsc/include/petsc/private/sectionimpl.h",
> > line 21: warning: operands have incompatible types:
> > struct {pointer to long long perm, pointer to long long invPerm} ":"
> > const struct {pointer to long long perm, pointer to long long invPerm}
> > "/export/home/glci/builds/zxfiRCGf/0/petsc/petsc/include/petsc/private/petscfeimpl.h",
> > line 19: warning: linker scope was specified more than once: "PETSCFE_SetUp"
> > On Mon, Jul 13, 2020 at 4:08 PM Mark Adams <mfadams at lbl.gov> wrote:
> >> On Mon, Jul 13, 2020 at 4:01 PM Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >>> Do these have -single-library ?
> >> This was in a single configuration, but it also happened in this one:
> >> /scratch/svcpetsc/glci-builds/qanz_veh/0/petsc/petsc/arch-ci-linux-pkgs-cxx-mlib/lib/libpetscdm.so:
> >> undefined reference to `TSGetDM'
> >> undefined reference to `DMPlexSNESComputeJacobianFEM'
> >> collect2: error: ld returned 1 exit status
> >> gmakefile.test:185: recipe for target
> >> 'arch-ci-linux-pkgs-cxx-mlib/tests/mat/tests/ex96' failed
> >> make[2]: *** [arch-ci-linux-pkgs-cxx-mlib/tests/mat/tests/ex96] Error 1
> >> make[2]: *** Waiting for unfinished jobs....
> >> /scratch/svcpetsc/glci-builds/qanz_veh/0/petsc/petsc/lib/petsc/conf/test.common:26:
> >> recipe for target 'allgtest-tap' failed
> >> make[1]: *** [allgtest-tap] Error 2
> >> GNUmakefile:17: recipe for target 'allgtests-tap' failed
> >> make: *** [allgtests-tap] Error 2
> >> Running after_script
> >>> Thanks,
> >>> Matt
> >>> On Mon, Jul 13, 2020 at 3:51 PM Mark Adams <mfadams at lbl.gov> wrote:
> >>>> I am getting this error on two pipeline tests. They don't seem to have
> >>>> anything to do with my branch. I have gotten these several times today.
> >>>> /home/petsc/builds/KFnbdjNX/0/petsc/petsc/arch-ci-linux-cuda-single-cxx/lib/libpetscdm.so:
> >>>> make[2]: *** [arch-ci-linux-cuda-single-cxx/tests/mat/tests/ex240]
> >>>> Error 1
> >>>> 'arch-ci-linux-cuda-single-cxx/tests/mat/tests/ex240' failed
> >>>> /home/petsc/builds/KFnbdjNX/0/petsc/petsc/lib/petsc/conf/test.common:26:
> >>> What most experimenters take for granted before they begin their
> >>> experiments is infinitely more interesting than any results to which their
> >>> experiments lead.
> >>> -- Norbert Wiener
> >>> https://www.cse.buffalo.edu/~knepley/
> >>> <http://www.cse.buffalo.edu/~knepley/>
