[petsc-dev] pipeline failure
Mark Adams mfadams at lbl.gov
Mon Jul 13 15:23:13 CDT 2020
I did add #include <petscts.h> to petscdmplex.h. THat is all that I can see
that could cause trouble.
On Mon, Jul 13, 2020 at 4:11 PM Mark Adams <mfadams at lbl.gov> wrote:
> THis error was in this one also, plus warnings:
> https://gitlab.com/petsc/petsc/-/jobs/636537354
> "/export/home/glci/builds/zxfiRCGf/0/petsc/petsc/include/petsc/private/sectionimpl.h",
> line 21: warning: operands have incompatible types:
> struct  {pointer to long long perm, pointer to long long invPerm} ":"
> const struct  {pointer to long long perm, pointer to long long invPerm}
> "/export/home/glci/builds/zxfiRCGf/0/petsc/petsc/include/petsc/private/petscfeimpl.h",
> line 19: warning: linker scope was specified more than once: "PETSCFE_SetUp"
> On Mon, Jul 13, 2020 at 4:08 PM Mark Adams <mfadams at lbl.gov> wrote:
>> On Mon, Jul 13, 2020 at 4:01 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> Do these have -single-library ?
>> This was in a single configuration, but it also happened in this one:
>> /scratch/svcpetsc/glci-builds/qanz_veh/0/petsc/petsc/arch-ci-linux-pkgs-cxx-mlib/lib/libpetscdm.so:
>> undefined reference to `TSGetDM'
>> undefined reference to `DMPlexSNESComputeJacobianFEM'
>> collect2: error: ld returned 1 exit status
>> gmakefile.test:185: recipe for target
>> 'arch-ci-linux-pkgs-cxx-mlib/tests/mat/tests/ex96' failed
>> make[2]: *** [arch-ci-linux-pkgs-cxx-mlib/tests/mat/tests/ex96] Error 1
>> make[2]: *** Waiting for unfinished jobs....
>> /scratch/svcpetsc/glci-builds/qanz_veh/0/petsc/petsc/lib/petsc/conf/test.common:26:
>> recipe for target 'allgtest-tap' failed
>> make[1]: *** [allgtest-tap] Error 2
>> GNUmakefile:17: recipe for target 'allgtests-tap' failed
>> make: *** [allgtests-tap] Error 2
>> Running after_script
>>>   Thanks,
>>>      Matt
>>> On Mon, Jul 13, 2020 at 3:51 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>> I am getting this error on two pipeline tests. They don't seem to have
>>>> anything to do with my branch. I have gotten these several times today.
>>>> /home/petsc/builds/KFnbdjNX/0/petsc/petsc/arch-ci-linux-cuda-single-cxx/lib/libpetscdm.so:
>>>> make[2]: *** [arch-ci-linux-cuda-single-cxx/tests/mat/tests/ex240]
>>>> Error 1
>>>> 'arch-ci-linux-cuda-single-cxx/tests/mat/tests/ex240' failed
>>>> /home/petsc/builds/KFnbdjNX/0/petsc/petsc/lib/petsc/conf/test.common:26:
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200713/68cdbd9d/attachment-0001.html>
