[petsc-dev] new Fortran error
Mark Adams
mfadams at lbl.gov
Fri Jul 10 09:57:33 CDT 2020
> I suspect you have upgraded gfortran and now have gfortran version 10,
09:35 knepley/feature-swarm-fortran= ~/Codes/petsc$ mpif90 --version
GNU Fortran (Homebrew GCC 10.1.0) 10.1.0
> which is pickier about argument matching.
> If you add -fallow-argument-mismatch to the fortran flags, do things go
> away?
Well, it turns 6 errors into 2 warnings:
FC arch-macosx-gnu-g/tests/dm/impls/swarm/tutorials/ex1f90.o
/Users/markadams/Codes/petsc/src/dm/impls/swarm/tutorials/ex1f90.F90:39:30:
34 | call PetscObjectSetName(dm, 'Potential Grid',
ierr);CHKERRA(ierr)
| 2
39 | call PetscObjectSetName(fe, 'fe', ierr);CHKERRA(ierr)
| 1
Warning: Type mismatch between actual argument at (1) and actual argument
at (2) (INTEGER(8)/TYPE(tdm)).
FLINKER arch-macosx-gnu-g/tests/dm/impls/swarm/tutorials/ex1f90
TEST
arch-macosx-gnu-g/tests/counts/dm_impls_swarm_tutorials-ex1f90_0.counts
ok dm_impls_swarm_tutorials-ex1f90_0
ok diff-dm_impls_swarm_tutorials-ex1f90_0
Oh well, I guess we need to add this param if we want to set names and take
it out of regression tests.
I wonder why it seems to say a PetsFE is an INTEGER(8) ...
> Lawrenmce
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200710/c19210f1/attachment.html>
