[petsc-dev] new Fortran error
Lawrence Mitchell
wence at gmx.li
Fri Jul 10 08:07:38 CDT 2020
> On 10 Jul 2020, at 13:53, Mark Adams <mfadams at lbl.gov> wrote:
> I just started getting this error and I have no idea what it from. Any ideas?
> 08:52 knepley/feature-swarm-fortran= ~/Codes/petsc$ make -f gmakefile test search='dm_impls_swarm_tutorials-ex1f90_0'
> Using MAKEFLAGS: search=dm_impls_swarm_tutorials-ex1f90_0
> FC arch-macosx-gnu-g/tests/dm/impls/swarm/tutorials/ex1f90.o
> /Users/markadams/Codes/petsc/src/dm/impls/swarm/tutorials/ex1f90.F90:39:30:
> 34 | call PetscObjectSetName(dm, 'Potential Grid', ierr);CHKERRA(ierr)
> | 2
> 39 | call PetscObjectSetName(fe, 'fe', ierr);CHKERRA(ierr)
> | 1
> Error: Type mismatch between actual argument at (1) and actual argument at (2) (INTEGER(8)/TYPE(tdm)).
> /Users/markadams/Codes/petsc/src/dm/impls/swarm/tutorials/ex1f90.F90:71:30:
> | 2
> 71 | call PetscObjectSetName(rho, 'rho', ierr);CHKERRA(ierr)
> | 1
> Error: Type mismatch between actual argument at (1) and actual argument at (2) (TYPE(tvec)/TYPE(tdm)).
> /Users/markadams/Codes/petsc/src/dm/impls/swarm/tutorials/ex1f90.F90:73:30:
> | 2
> 73 | call PetscObjectSetName(f, 'weights', ierr);CHKERRA(ierr)
> | 1
I suspect you have upgraded gfortran and now have gfortran version 10, which is pickier about argument matching.
If you add -fallow-argument-mismatch to the fortran flags, do things go away?
Lawrenmce
