[petsc-dev] Sphinx error
Jacob Faibussowitsch jacob.fai at gmail.com
Mon Jul 6 20:24:51 CDT 2020
>> Running Sphinx v3.0.4
>> Found DOT install: /usr/local/bin/dot
Glad to see my rudimentary check for DOT is still working. Graphviz should also be added to requirements in that case. I believe it errors if it cannot find dot.
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Jul 6, 2020, at 8:20 PM, Jed Brown <jed at jedbrown.org> wrote:
> Gotta run
>  pip install -r src/docs/sphinx_docs/requirements.txt
> Add --user if you aren't in a virtualenv.
> Barry Smith <bsmith at petsc.dev> writes:
>> Extension error:
>> Could not import extension sphinxcontrib.bibtex (exception: No module named 'sphinxcontrib.bibtex')
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200706/68126ec6/attachment.html>
