[petsc-dev] Sphinx error
Barry Smith bsmith at petsc.dev
Mon Jul 6 20:37:31 CDT 2020
 make alldoc or whatever should help one with this. Not just send off a sphinx error.
  Barry
> On Jul 6, 2020, at 8:20 PM, Jed Brown <jed at jedbrown.org> wrote:
> Gotta run
>  pip install -r src/docs/sphinx_docs/requirements.txt
> Add --user if you aren't in a virtualenv.
> Barry Smith <bsmith at petsc.dev> writes:
>> Running Sphinx v3.0.4
>> Found DOT install: /usr/local/bin/dot
>> Extension error:
>> Could not import extension sphinxcontrib.bibtex (exception: No module named 'sphinxcontrib.bibtex')
