[petsc-dev] Sphinx error
Jed Brown jed at jedbrown.org
Mon Jul 6 20:20:50 CDT 2020
Gotta run
  pip install -r src/docs/sphinx_docs/requirements.txt
Add --user if you aren't in a virtualenv.
Barry Smith <bsmith at petsc.dev> writes:
> Running Sphinx v3.0.4
> Found DOT install: /usr/local/bin/dot
> Extension error:
> Could not import extension sphinxcontrib.bibtex (exception: No module named 'sphinxcontrib.bibtex')
