[petsc-dev] git status to test list
Barry Smith
bsmith at petsc.dev
Mon Jul 6 16:08:20 CDT 2020
> On Jul 6, 2020, at 3:48 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at petsc.dev> writes:
>> We should be more clever than checking just examples but also check source code. If, for example, only KSP is changed then tests could skip the sys/vec/mat levels saving time.
>> If we did this in the pipeline they could be significantly faster; all the time saved not testing sys to mat for Matt's changes :-)
>> Is there a fallacy here?
> I think we could pretty readily do this at the granularity of package. Significantly harder (would need to interface with a coverage tool) to do it at finer granularity.
> What fraction of our testing time is currently at petscmat and below?
No idea, but could easily be 1/3
