[petsc-dev] git status to test list
Jed Brown
jed at jedbrown.org
Mon Jul 6 15:48:57 CDT 2020
Barry Smith <bsmith at petsc.dev> writes:
> We should be more clever than checking just examples but also check source code. If, for example, only KSP is changed then tests could skip the sys/vec/mat levels saving time.
> If we did this in the pipeline they could be significantly faster; all the time saved not testing sys to mat for Matt's changes :-)
> Is there a fallacy here?
I think we could pretty readily do this at the granularity of package. Significantly harder (would need to interface with a coverage tool) to do it at finer granularity.
What fraction of our testing time is currently at petscmat and below?
