[petsc-dev] git status to test list
Jacob Faibussowitsch
jacob.fai at gmail.com
Mon Jul 6 13:15:08 CDT 2020
> If we did this in the pipeline they could be significantly faster
We might also consider not locking _all_ stage n+1 jobs behind completion of stage n. Gitlab supports this via the “needs” command https://gitlab.com/help/ci/yaml/README.md#needs <https://gitlab.com/help/ci/yaml/README.md#needs> which allows you to run jobs immediately after their prerequisite jobs have finished regardless of stage. For example, I find that I am quite often waiting on stage 2 freebsd jobs to start in order to advance to stage 3, even after every other stage 2 job has run its course.
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Jul 6, 2020, at 12:47 PM, Barry Smith <bsmith at petsc.dev> wrote:
> We should be more clever than checking just examples but also check source code. If, for example, only KSP is changed then tests could skip the sys/vec/mat levels saving time.
> If we did this in the pipeline they could be significantly faster; all the time saved not testing sys to mat for Matt's changes :-)
> Is there a fallacy here?
> Barry
> Need to check changes in include files as well, of course.
>> On Jul 6, 2020, at 12:13 PM, Jacob Faibussowitsch <jacob.fai at gmail.com <mailto:jacob.fai at gmail.com>> wrote:
>> While were on this topic, I always parse git diff —name-only $(git merge-base —fork-point master) when testing. This gives you all the files that are different between your branch and master. You can switch it out for maint if needs be.
>> Best regards,
>>> On Jul 6, 2020, at 12:00 PM, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>> I couldn't see how Jed can avoid doing the filename hacking since alltesttargets are the hacked filenames but probably I am missing something.
>>> Anyways this patch works for me based on Jed's email.
>>> Barry
>>> <since.patch>
>>>> On Jul 6, 2020, at 9:40 AM, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
>>>> It'd be possible to hack the file names, but I'd rather not duplicate that logic.
>>>> My inclination would be to filter similar to argsearch, which requires
>>>> adding the source files to testfiles. Then you could use
>>>> make test since=@
>>>> ifdef since
>>>> gitchanged := $(shell git diff --name-only $(since) src/)
>>>> endif
>>>> Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>> writes:
>>>>> Hello,
>>>>> To git/regexp enthusiasts and/or test harness people: is there some script/command lying around to convert a list of modified examples (according to git) into a list understandable by the test system?
>>>>> Thanks for your help,
>>>>> Pierre
>>>>> PS: here is such a list
>>>>> $ git status -uno
>>>>> On branch master
>>>>> Your branch is up to date with 'origin/master'.
>>>>> Changes not staged for commit:
>>>>> (use "git add <file>..." to update what will be committed)
>>>>> (use "git checkout -- <file>..." to discard changes in working directory)
>>>>> modified: config/BuildSystem/config/types.py
>>>>> modified: include/petscsys.h
>>>>> modified: src/dm/label/tutorials/ex1f90.F90
>>>>> modified: src/ksp/ksp/tests/ex16f.F90
>>>>> modified: src/ksp/ksp/tutorials/ex5f.F90
>>>>> modified: src/ksp/ksp/tutorials/ex75f.F90
>>>>> modified: src/ksp/ksp/tutorials/ex76f.F90
>>>>> modified: src/ksp/ksp/tutorials/ex77f.F90
>>>>> modified: src/ksp/ksp/tutorials/ex7f.F90
>>>>> modified: src/mat/tests/ex196f90.F90
>>>>> modified: src/sys/tests/ex13f.F90
>>>>> modified: src/sys/tests/ex47f.F90
>>>>> modified: src/sys/tutorials/ex17f.F90
>>>>> modified: src/sys/tutorials/ex2f.F90
>>>>> modified: src/vec/vec/tutorials/ex11f90.F90
>>>>> modified: src/vec/vec/tutorials/ex18f.F90
>>>>> modified: src/vec/vec/tutorials/ex1f.F90
>>>>> no changes added to commit (use "git add" and/or "git commit -a")
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200706/05c49e18/attachment.html>
