[petsc-dev] git status to test list
Barry Smith
bsmith at petsc.dev
Mon Jul 6 12:47:30 CDT 2020
We should be more clever than checking just examples but also check source code. If, for example, only KSP is changed then tests could skip the sys/vec/mat levels saving time.
If we did this in the pipeline they could be significantly faster; all the time saved not testing sys to mat for Matt's changes :-)
Is there a fallacy here?
Barry
Need to check changes in include files as well, of course.
> On Jul 6, 2020, at 12:13 PM, Jacob Faibussowitsch <jacob.fai at gmail.com> wrote:
> While were on this topic, I always parse git diff —name-only $(git merge-base —fork-point master) when testing. This gives you all the files that are different between your branch and master. You can switch it out for maint if needs be.
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
>> On Jul 6, 2020, at 12:00 PM, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>> I couldn't see how Jed can avoid doing the filename hacking since alltesttargets are the hacked filenames but probably I am missing something.
>> Anyways this patch works for me based on Jed's email.
>> Barry
>> <since.patch>
>>> On Jul 6, 2020, at 9:40 AM, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
>>> It'd be possible to hack the file names, but I'd rather not duplicate that logic.
>>> My inclination would be to filter similar to argsearch, which requires
>>> adding the source files to testfiles. Then you could use
>>> make test since=@
>>> ifdef since
>>> gitchanged := $(shell git diff --name-only $(since) src/)
>>> endif
>>> Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>> writes:
>>>> Hello,
>>>> To git/regexp enthusiasts and/or test harness people: is there some script/command lying around to convert a list of modified examples (according to git) into a list understandable by the test system?
>>>> Thanks for your help,
>>>> Pierre
>>>> PS: here is such a list
>>>> $ git status -uno
>>>> On branch master
>>>> Your branch is up to date with 'origin/master'.
>>>> Changes not staged for commit:
>>>> (use "git add <file>..." to update what will be committed)
>>>> (use "git checkout -- <file>..." to discard changes in working directory)
>>>> modified: config/BuildSystem/config/types.py
>>>> modified: include/petscsys.h
>>>> modified: src/dm/label/tutorials/ex1f90.F90
>>>> modified: src/ksp/ksp/tests/ex16f.F90
>>>> modified: src/ksp/ksp/tutorials/ex5f.F90
>>>> modified: src/ksp/ksp/tutorials/ex75f.F90
>>>> modified: src/ksp/ksp/tutorials/ex76f.F90
>>>> modified: src/ksp/ksp/tutorials/ex77f.F90
>>>> modified: src/ksp/ksp/tutorials/ex7f.F90
>>>> modified: src/mat/tests/ex196f90.F90
>>>> modified: src/sys/tests/ex13f.F90
>>>> modified: src/sys/tests/ex47f.F90
>>>> modified: src/sys/tutorials/ex17f.F90
>>>> modified: src/sys/tutorials/ex2f.F90
>>>> modified: src/vec/vec/tutorials/ex11f90.F90
>>>> modified: src/vec/vec/tutorials/ex18f.F90
>>>> modified: src/vec/vec/tutorials/ex1f.F90
>>>> no changes added to commit (use "git add" and/or "git commit -a")
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200706/35d7e3e3/attachment-0001.html>
