[petsc-dev] git status to test list
Jacob Faibussowitsch
jacob.fai at gmail.com
Mon Jul 6 12:13:08 CDT 2020
While were on this topic, I always parse git diff —name-only $(git merge-base —fork-point master) when testing. This gives you all the files that are different between your branch and master. You can switch it out for maint if needs be.
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Jul 6, 2020, at 12:00 PM, Barry Smith <bsmith at petsc.dev> wrote:
> I couldn't see how Jed can avoid doing the filename hacking since alltesttargets are the hacked filenames but probably I am missing something.
> Anyways this patch works for me based on Jed's email.
> Barry
> <since.patch>
>> On Jul 6, 2020, at 9:40 AM, Jed Brown <jed at jedbrown.org> wrote:
>> It'd be possible to hack the file names, but I'd rather not duplicate that logic.
>> My inclination would be to filter similar to argsearch, which requires
>> adding the source files to testfiles. Then you could use
>> make test since=@
>> ifdef since
>> gitchanged := $(shell git diff --name-only $(since) src/)
>> endif
>> Pierre Jolivet <pierre.jolivet at enseeiht.fr> writes:
>>> Hello,
>>> To git/regexp enthusiasts and/or test harness people: is there some script/command lying around to convert a list of modified examples (according to git) into a list understandable by the test system?
>>> Thanks for your help,
>>> Pierre
>>> PS: here is such a list
>>> $ git status -uno
>>> On branch master
>>> Your branch is up to date with 'origin/master'.
>>> Changes not staged for commit:
>>> (use "git add <file>..." to update what will be committed)
>>> (use "git checkout -- <file>..." to discard changes in working directory)
>>> modified: config/BuildSystem/config/types.py
>>> modified: include/petscsys.h
>>> modified: src/dm/label/tutorials/ex1f90.F90
>>> modified: src/ksp/ksp/tests/ex16f.F90
>>> modified: src/ksp/ksp/tutorials/ex5f.F90
>>> modified: src/ksp/ksp/tutorials/ex75f.F90
>>> modified: src/ksp/ksp/tutorials/ex76f.F90
>>> modified: src/ksp/ksp/tutorials/ex77f.F90
>>> modified: src/ksp/ksp/tutorials/ex7f.F90
>>> modified: src/mat/tests/ex196f90.F90
>>> modified: src/sys/tests/ex13f.F90
>>> modified: src/sys/tests/ex47f.F90
>>> modified: src/sys/tutorials/ex17f.F90
>>> modified: src/sys/tutorials/ex2f.F90
>>> modified: src/vec/vec/tutorials/ex11f90.F90
>>> modified: src/vec/vec/tutorials/ex18f.F90
>>> modified: src/vec/vec/tutorials/ex1f.F90
>>> no changes added to commit (use "git add" and/or "git commit -a")
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200706/3f050d7c/attachment.html>
