[petsc-dev] how do see artifacts?
Jed Brown
jed at jedbrown.org
Sun Jan 19 22:39:42 CST 2020
"Smith, Barry F. via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
> I have no left hand side.
Right hand side? I certainly see them. Are you using a funny browser?
> If I grab the left hand side with the mouse and pull it in or out
> sometimes I get the left hand panel, sometimes not.
> Barry
>> On Jan 19, 2020, at 10:16 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
>> For some reason I can't access this job URL anymore. Ok checking a different one
>> https://gitlab.com/petsc/petsc/-/jobs/407945185
>> Attaching what I see [with the 'artifact' section in the right side column]
>> Satish
>> On Mon, 20 Jan 2020, Smith, Barry F. via petsc-dev wrote:
>>>> On Jan 19, 2020, at 7:13 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
>>>> For which job are you seeing this problem?
>>>> For ex: https://gitlab.com/petsc/petsc/-/jobs/408092654 has
>>> Where? I got to that page and it has the big black scrolling of the run output at the top it has a trash can and up and down arrows for the top and bottom of the file and a button for the raw data. No links or anything to artifacts.
>>> Do you literally need to type artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log in the address bar in the browser to find them?
>>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/download
>>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/browse
>>>> I usually browse and look for configure.log for ex:
>>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log
>>>> Satish
>>>> On Sun, 19 Jan 2020, Smith, Barry F. via petsc-dev wrote:
>>>>> With the new Gitlab interfaces how do you see the artifacts for failed pipelines/tests? I can't find them anywhere. It just takes me straight to the output with no sidebar for artifacts?
>>>>> Thanks
>>>>> Barry
>> <gitlab-artifacts.png>
