[petsc-dev] how do see artifacts?
Smith, Barry F. bsmith at mcs.anl.gov
Sun Jan 19 22:29:30 CST 2020
  I have no left hand side. If I grab the left hand side with the mouse and pull it in or out sometimes I get the left hand panel, sometimes not.
   Barry
> On Jan 19, 2020, at 10:16 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> For some reason I can't access this job URL anymore. Ok checking a different one
> https://gitlab.com/petsc/petsc/-/jobs/407945185
> Attaching what I see [with the 'artifact' section in the right side column]
> Satish
> On Mon, 20 Jan 2020, Smith, Barry F. via petsc-dev wrote:
>>> On Jan 19, 2020, at 7:13 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
>>> For which job are you seeing this problem?
>>> For ex: https://gitlab.com/petsc/petsc/-/jobs/408092654 has
>>  Where? I got to that page and it has the big black scrolling of the run output at the top it has a trash can and up and down arrows for the top and bottom of the file and a button for the raw data. No links or anything to artifacts.
>>   Do you literally need to type artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log in the address bar in the browser to find them?
>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/download
>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/browse
>>> I usually browse and look for configure.log for ex:
>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log
>>> Satish
>>> On Sun, 19 Jan 2020, Smith, Barry F. via petsc-dev wrote:
>>>>  With the new Gitlab interfaces how do you see the artifacts for failed pipelines/tests? I can't find them anywhere. It just takes me straight to the output with no sidebar for artifacts?
>>>>   Thanks
>>>>     Barry
> <gitlab-artifacts.png>
