[petsc-dev] how do see artifacts?
Smith, Barry F. bsmith at mcs.anl.gov
Sun Jan 19 22:41:34 CST 2020
> On Jan 19, 2020, at 10:39 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F. via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
>>  I have no left hand side.
> Right hand side?  I certainly see them.  Are you using a funny browser?
  Apple's :-)
>>  If I grab the left hand side with the mouse and pull it in or out
>>  sometimes I get the left hand panel, sometimes not.
>>   Barry
>>> On Jan 19, 2020, at 10:16 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
>>> For some reason I can't access this job URL anymore. Ok checking a different one
>>> https://gitlab.com/petsc/petsc/-/jobs/407945185
>>> Attaching what I see [with the 'artifact' section in the right side column]
>>> Satish
>>> On Mon, 20 Jan 2020, Smith, Barry F. via petsc-dev wrote:
>>>>> On Jan 19, 2020, at 7:13 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
>>>>> For which job are you seeing this problem?
>>>>> For ex: https://gitlab.com/petsc/petsc/-/jobs/408092654 has
>>>> Where? I got to that page and it has the big black scrolling of the run output at the top it has a trash can and up and down arrows for the top and bottom of the file and a button for the raw data. No links or anything to artifacts.
>>>>  Do you literally need to type artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log in the address bar in the browser to find them?
>>>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/download
>>>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/browse
>>>>> I usually browse and look for configure.log for ex:
>>>>> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log
>>>>> Satish
>>>>> On Sun, 19 Jan 2020, Smith, Barry F. via petsc-dev wrote:
>>>>>> With the new Gitlab interfaces how do you see the artifacts for failed pipelines/tests? I can't find them anywhere. It just takes me straight to the output with no sidebar for artifacts?
>>>>>>  Thanks
>>>>>>    Barry
>>> <gitlab-artifacts.png>
