[petsc-dev] how do see artifacts?
    Balay, Satish
    balay at mcs.anl.gov
    Sun Jan 19 22:16:55 CST 2020
For some reason I can't access this job URL anymore. Ok checking a different one
https://gitlab.com/petsc/petsc/-/jobs/407945185
Attaching what I see [with the 'artifact' section in the right side column]
Satish
On Mon, 20 Jan 2020, Smith, Barry F. via petsc-dev wrote:
> > On Jan 19, 2020, at 7:13 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> > For which job are you seeing this problem?
> > For ex: https://gitlab.com/petsc/petsc/-/jobs/408092654 has
>   Where? I got to that page and it has the big black scrolling of the run output at the top it has a trash can and up and down arrows for the top and bottom of the file and a button for the raw data. No links or anything to artifacts.
>    Do you literally need to type artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log in the address bar in the browser to find them?
> > https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/download
> > https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/browse
> > I usually browse and look for configure.log for ex:
> > https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log
> > Satish
> > On Sun, 19 Jan 2020, Smith, Barry F. via petsc-dev wrote:
> >>   With the new Gitlab interfaces how do you see the artifacts for failed pipelines/tests? I can't find them anywhere. It just takes me straight to the output with no sidebar for artifacts?
> >>    Thanks
> >>      Barry
Type: image/png
Desc: gitlab-artifacts.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200120/2c462ee1/attachment-0001.png>
