[petsc-dev] how do see artifacts?
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Sun Jan 19 21:43:35 CST 2020
> On Jan 19, 2020, at 7:13 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> For which job are you seeing this problem?
> For ex: https://gitlab.com/petsc/petsc/-/jobs/408092654 has
  Where? I got to that page and it has the big black scrolling of the run output at the top it has a trash can and up and down arrows for the top and bottom of the file and a button for the raw data. No links or anything to artifacts.
   Do you literally need to type artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log in the address bar in the browser to find them?
> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/download
> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/browse
> I usually browse and look for configure.log for ex:
> https://gitlab.com/petsc/petsc/-/jobs/408092654/artifacts/file/arch-linux2-c-opt/lib/petsc/conf/configure.log
> Satish
> On Sun, 19 Jan 2020, Smith, Barry F. via petsc-dev wrote:
>>   With the new Gitlab interfaces how do you see the artifacts for failed pipelines/tests? I can't find them anywhere. It just takes me straight to the output with no sidebar for artifacts?
>>    Thanks
>>      Barry
