[petsc-dev] Issue with dependency generation in GCC 9
    Satish Balay
    balay at mcs.anl.gov
    Wed Feb 19 10:08:31 CST 2020
Fedora 32 now has a  ccache 3.7.7 update [in testing]
https://bodhi.fedoraproject.org/updates/FEDORA-2020-303fd70614
Satish
On Mon, 20 Jan 2020, Lisandro Dalcin wrote:
> Indeed! First bug fix listed here:
> https://ccache.dev/releasenotes.html#_ccache_3_7_7
> Thanks all and sorry for the noise!
> On Mon, 20 Jan 2020 at 21:33, Balay, Satish <balay at mcs.anl.gov> wrote:
> > And looks like the issue is fixed in ccache 3.7.7
> > Satish
> > balay at sb /home/balay/petsc (master=)
> > $ which gcc
> > /usr/lib64/ccache/gcc
> > $ ccache --version
> > ccache version 3.7.7
> > Copyright (C) 2002-2007 Andrew Tridgell
> > Copyright (C) 2009-2020 Joel Rosdahl
> > This program is free software; you can redistribute it and/or modify it
> > under
> > the terms of the GNU General Public License as published by the Free
> > Software
> > Foundation; either version 3 of the License, or (at your option) any later
> > version.
> > $ make clean
> > /usr/bin/rm -f -r ./arch-linux-c-debug/tests
> > ./arch-linux-c-debug/tests/testfiles
> > /usr/bin/rm -f -r arch-linux-c-debug/obj arch-linux-c-debug/lib/libpetsc*
> > /home/balay/petsc/arch-linux-c-debug/include/petsc*.mod
> > arch-linux-c-debug/lib/petsc/conf/files
> > $ make -f gmakefile arch-linux-c-debug/obj/sys/objects/init.o
> > /usr/bin/python ./config/gmakegen.py --petsc-arch=arch-linux-c-debug
> > /usr/bin/python /home/balay/petsc/config/gmakegentest.py
> > --petsc-dir=/home/balay/petsc --petsc-arch=arch-linux-c-debug
> > --testdir=./arch-linux-c-debug/tests
> > Use "/usr/bin/gmake V=1" to see verbose compile lines, "/usr/bin/gmake
> > V=0" to suppress.
> >           CC arch-linux-c-debug/obj/sys/objects/init.o
> > $ head -n 3 arch-linux-c-debug/obj/sys/objects/init.d
> > arch-linux-c-debug/obj/sys/objects/init.o: \
> >  /home/balay/petsc/src/sys/objects/init.c \
> >  /home/balay/petsc/include/petscsys.h \
> > make: 'arch-linux-c-debug/obj/sys/objects/init.o' is up to date.
> > $ touch /home/balay/petsc/include/petscsys.h
> > V=0" to suppress.
> > On Mon, 20 Jan 2020, Balay, Satish via petsc-dev wrote:
> > > Downgrading to ccache-3.4.3-2.fc30.x86_64.rpm [on F31] changes this
> > behavior for me.
> > > Satish
> > > wget
> > https://kojipkgs.fedoraproject.org//packages/ccache/3.4.3/2.fc30/x86_64/ccache-3.4.3-2.fc30.x86_64.rpm
> > > rpm -Uvh --oldpackage ccache-3.4.3-2.fc30.x86_64.rpm
> > > > Ups! Not a GCC issue, but still relevant to all us...
> > > > The issue happens only if using ccache. I have the system ccache
> > package
> > > > installed, and ccache is used via symlinks.
> > > > $ mpicc -show
> > > > gcc -I/usr/include/mpich-x86_64 -L/usr/lib64/mpich/lib -Wl,-rpath
> > > > -Wl,/usr/lib64/mpich/lib -Wl,--enable-new-dtags -lmpi
> > > > $ which gcc
> > > > Rebuilding this way:
> > > > $ make clean
> > > > $ MPICH_CC=/usr/bin/gcc make
> > > > $ head -n 3 arch-linux2-c-debug/obj/sys/objects/init.d
> > > > arch-linux2-c-debug/obj/sys/objects/init.o: \
> > > >  /home/devel/petsc/dev/src/sys/objects/init.c \
> > > >  /home/devel/petsc/dev/include/petscsys.h \
> > > > so I'm back to normal.
> > > > Now I need to figure out if this is a ccache miss-configuration (maybe
> > from
> > > > legacy values in my $HOME config file) or something else.
> > > > On Mon, 20 Jan 2020 at 18:42, <jed at jedbrown.org> wrote:
> > > > > Ah, you're right. I'm still suspicious about how this behavior
> > appeared on
> > > > > your machine. Would be interesting to check a vanilla build or gcc-10
> > > > > branch. I'm still learning toward it being unintentional.
> > > > > On Jan 20, 2020 07:57, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> > > > > On Mon, 20 Jan 2020 at 17:07, Jed Brown <jed at jedbrown.org> wrote:
> > > > > From my man page (contradicting the behavior Lisandro observed):
> > > > >    -MD -MD is equivalent to -M -MF file, except that -E is not
> > implied.
> > > > > The driver
> > > > >        determines file based on whether an -o option is given.  If
> > it is,
> > > > > the driver uses
> > > > >        its argument but with a suffix of .d, otherwise it takes the
> > name
> > > > > of the input
> > > > >        file, removes any directory components and suffix, and
> > applies a .d
> > > > > suffix.
> > > > > Lisandro, what does your man page say?
> > > > > It says exactly the same. But you are confusing the flag, -MF is
> > about
> > > > > naming the output dep filename, i.e.
> > ompi-optg/obj/sys/objects/init.d in
> > > > > your example, that is just fine, I do get that file with that name.
> > > > > My issue is with the contents GCC writes within that dep file,
> > > > > specifically the TARGET, which can be specified with -MT, but it is
> > > > > cumbersome to do, unless you use "-MT $@", though no idea how to
> > update
> > > > > configure for that.
> > > > > Lisandro Dalcin
> > > > > Research Scientist
> > > > > Extreme Computing Research Center (ECRC)
> > > > > King Abdullah University of Science and Technology (KAUST)
> > > > > http://ecrc.kaust.edu.sa/
