[petsc-dev] Unguarded framework.logClear() in config/configure.py
Jed Brown
jed at jedbrown.org
Wed Feb 19 09:35:39 CST 2020
"Ham, David A" <david.ham at imperial.ac.uk> writes:
> Dear all,
> I have a user reporting a petsc build fail on line 517 of config/configure.py because framework is None.
> This line was added by Barry in: https://gitlab.com/petsc/petsc/-/commit/f8c648457d28782525df1eae155c6b3ed2cce293
> However the same line occurs three lines after, this time guarded by “if not framework is None:” I wonder if the new logClear should be there at all…
> The code in question is:
> print(msg)
Yup, I agree this new line should be deleted. Also, this should be
sufficient:
if framework:
I'm not wild about the quality of the traces/output with this exception
handling mechanism, and find myself often hacking this code to get traces.
