[petsc-dev] Testing seems broken in master
Thu Dec 31 13:02:07 CST 2020
On Thu, Dec 31, 2020 at 1:48 PM Barry Smith <bsmith at petsc.dev> wrote:
>   So the programs output changes and should no longer match that in the
> output/* file yet the test harness does not error with a statement that the
> two outputs do not match?
>    I noticed the gmakegentest.py is not being run before it runs the test?
> Does this mean it is just running all the old stuff which does match fine?
>    Then either how petscdiff is called by the test harness has changed or
> petscdiff has changed and does not detect changes anymore
>    BTW: I always use -f ./gmakefile.test test not just the gmakefile
>    All the PETSc changes are trivial and can be seen with a simple diff,
> it is hard to believe they would cause this behavior but I guess they must.
>    You can go to PETSC_ARCH/tests/snes/tests and run the ex13 shell script
> directly.
It is the sed problem:
master *$:/PETSc3/petsc/petsc-dev$
/PETSc3/petsc/petsc-dev/lib/petsc/bin/petscdiff
/PETSc3/petsc/petsc-dev/src/snes/tests/output/ex13_bench.out ex13_bench.tmp
sed: 1: "s/\033[1;31m//g": unbalanced brackets ([])
sed: 1: "s/\033[0;39m\033[0;49m//g": unbalanced brackets ([])
The error was getting eaten.
This is in current master. Is it fixed in a branch?
   Matt
>   Barry
> On Dec 31, 2020, at 12:38 PM, Matthew Knepley <knepley at gmail.com> wrote:
> I just pulled master, and simple alterations to tests do not produce a
> failure:
> master *$:/PETSc3/petsc/petsc-dev$ PETSC_ARCH=arch-master-debug make -f
> ./gmakefile test search="snes_tests-ex13_bench" TIMEOUT=5000
> EXTRA_OPTIONS="-dm_
> refine 0"
> Using MAKEFLAGS: EXTRA_OPTIONS=-dm_refine 0 TIMEOUT=5000
> search=snes_tests-ex13_bench
>         TEST arch-master-debug/tests/counts/snes_tests-ex13_bench.counts
>  ok snes_tests-ex13_bench
>  ok diff-snes_tests-ex13_bench
> I check that the runs produce different output when done manually.
> Scott and Barry, could this be related to changed to testing?
>   Thanks,
>      Matt
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201231/8ba2259b/attachment-0001.html>
