[petsc-dev] Testing seems broken in master
Barry Smith
bsmith at petsc.dev
Thu Dec 31 12:48:25 CST 2020
So the programs output changes and should no longer match that in the output/* file yet the test harness does not error with a statement that the two outputs do not match?
I noticed the gmakegentest.py is not being run before it runs the test? Does this mean it is just running all the old stuff which does match fine?
Then either how petscdiff is called by the test harness has changed or petscdiff has changed and does not detect changes anymore
BTW: I always use -f ./gmakefile.test test not just the gmakefile
All the PETSc changes are trivial and can be seen with a simple diff, it is hard to believe they would cause this behavior but I guess they must.
You can go to PETSC_ARCH/tests/snes/tests and run the ex13 shell script directly.
Barry
> On Dec 31, 2020, at 12:38 PM, Matthew Knepley <knepley at gmail.com> wrote:
> I just pulled master, and simple alterations to tests do not produce a failure:
> master *$:/PETSc3/petsc/petsc-dev$ PETSC_ARCH=arch-master-debug make -f ./gmakefile test search="snes_tests-ex13_bench" TIMEOUT=5000 EXTRA_OPTIONS="-dm_
> refine 0"
> Using MAKEFLAGS: EXTRA_OPTIONS=-dm_refine 0 TIMEOUT=5000 search=snes_tests-ex13_bench
> TEST arch-master-debug/tests/counts/snes_tests-ex13_bench.counts
> ok snes_tests-ex13_bench
> ok diff-snes_tests-ex13_bench
> I check that the runs produce different output when done manually.
> Scott and Barry, could this be related to changed to testing?
> Thanks,
> Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201231/49b5b96f/attachment.html>
