[petsc-dev] Testing seems broken in master
Matthew Knepley
knepley at gmail.com
Thu Dec 31 12:38:55 CST 2020
I just pulled master, and simple alterations to tests do not produce a
failure:
master *$:/PETSc3/petsc/petsc-dev$ PETSC_ARCH=arch-master-debug make -f
./gmakefile test search="snes_tests-ex13_bench" TIMEOUT=5000
EXTRA_OPTIONS="-dm_
refine 0"
Using MAKEFLAGS: EXTRA_OPTIONS=-dm_refine 0 TIMEOUT=5000
search=snes_tests-ex13_bench
TEST arch-master-debug/tests/counts/snes_tests-ex13_bench.counts
ok snes_tests-ex13_bench
ok diff-snes_tests-ex13_bench
I check that the runs produce different output when done manually.
Scott and Barry, could this be related to changed to testing?
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201231/266ee560/attachment.html>
