[petsc-dev] rebase problem
    Mark Adams
    mfadams at lbl.gov
    Sun Dec  6 20:16:43 CST 2020
I did it with HEAD~5 but it had like 40 commits. I rebased over master
recently and I think it sucked in the commits that I pulled in from that.
But then I aborted that and rebased over master. It seems to be OK now,
On Sun, Dec 6, 2020 at 8:03 PM Matthew Knepley <knepley at gmail.com> wrote:
> Mark, I think you need to tell it exactly where to start for your rebase.
> Suppose you have 4 commits. You want something like
>   git rebase -i HEAD~4
>   Thanks,
>      Matt
> On Sun, Dec 6, 2020 at 5:19 PM Mark Adams <mfadams at lbl.gov> wrote:
>> When I rebase over master I get conflicts in my files, alas.
>> I am thinking I should skip all the conflicts and then fix conflicts in
>> the files that I touched and checkout any others from master ... Satish?
>> 17:12 1 adams/landau-gpu-assembly *+|REBASE 29/58 ~/petsc$ git status
>> # HEAD detached from 3659b78
>> # You are currently rebasing branch 'adams/landau-gpu-assembly' on
>> '3659b78'.
>> #   (fix conflicts and then run "git rebase --continue")
>> #   (use "git rebase --skip" to skip this patch)
>> #   (use "git rebase --abort" to check out the original branch)
>> # Unmerged paths:
>> #   (use "git reset HEAD <file>..." to unstage)
>> #   (use "git add <file>..." to mark resolution)
>> # both modified:      include/petsclandau.h
>> # both modified:      src/ts/utils/dmplexlandau/cuda/landaucu.cu
>> # both modified:      src/ts/utils/dmplexlandau/kokkos/landau.kokkos.cxx
>> # both modified:      src/ts/utils/dmplexlandau/plexland.c
>> # both modified:      src/ts/utils/dmplexlandau/tutorials/output/ex1_0.out
>> # both modified:      src/ts/utils/dmplexlandau/tutorials/output/ex2_0.out
>> On Sun, Dec 6, 2020 at 4:35 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
>> wrote:
>>> I would first rebase your branch over latest master and then perform
>>> your squash. Otherwise you will be squashing other commits which have
>>> become part of your branch history (perhaps via updating your branch by
>>> intermittently merging, not rebasing, master into it). It seems like that
>>> is what is happening right now, although maybe Satish will know better.
>>> Best regards,
>>> (Jacob Fai - booss - oh - vitch)
>>> Cell: (312) 694-3391
>>> On Dec 6, 2020, at 15:30, Mark Adams <mfadams at lbl.gov> wrote:
>>> This is the status after the first fail. I have nothing to do with these
>>> files. There are diffs, but I don't know anything about them.
>>> Maybe I should skip failures (lot of them) and then checkout the
>>> conflicted files from master, then rebase over master?
>>> Thanks,
>>> Mark
>>> 6:24 1 adams/landau-gpu-assembly *+|REBASE-i 41/76 ~/petsc$ git status
>>> -uno
>>> # HEAD detached from 564e279
>>> '0c5056a'.
>>> # Changes to be committed:
>>> # new file:   src/snes/tutorials/output/ex19_asm_matconvert.out
>>> # Unmerged paths:
>>> # both modified:      src/snes/tutorials/ex19.c
>>> # Untracked files not listed (use -u option to show untracked files)
>>> 16:25 adams/landau-gpu-assembly *+|REBASE-i 41/76 ~/petsc$
>>> On Sun, Dec 6, 2020 at 3:48 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
>>> wrote:
>>>> Mark,
>>>> What is the output of git status when it fails? Any files that are
>>>> marked staged/uncommitted?
>>>> I’ve found that rebase will only work out of the box if your branch
>>>> history is completely linear, i.e. no merge commits in between. If there
>>>> are merge commits then git is not always able to resolve them. If this is
>>>> the case then when the rebase fails at some commit some of the files will
>>>> be staged with the changes from both commits that you must __manually__
>>>> reconcile.
>>>> Best regards,
>>>> On Dec 6, 2020, at 14:22, Mark Adams <mfadams at lbl.gov> wrote:
>>>> I am doing a rebase -i to squash commits and even if I do nothing git
>>>> tris to apply about 7) commits, but starts to fail at #41 and if I try to
>>>> --skip it it starts failing on every one. The error message is not very
>>>> useful to me:
>>>> 15:15 adams/landau-gpu-assembly> ~/petsc$ git rebase -i HEAD~5
>>>> error: could not apply a8e4255... Add test of PCASMSetSubMatType with
>>>> nonlinear problem
>>>> When you have resolved this problem, run "git rebase --continue".
>>>> If you prefer to skip this patch, run "git rebase --skip" instead.
>>>> To check out the original branch and stop rebasing, run "git rebase
>>>> --abort".
>>>> Could not apply a8e4255... Add test of PCASMSetSubMatType with
>>>> nonlinear problem
>>>> Any ideas?  Maybe rebase over master first?
>>>> Thanks,
>>>> Mark
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201206/dbf87c9d/attachment-0001.html>
