[petsc-dev] rebase problem
    Matthew Knepley
    knepley at gmail.com
    Sun Dec  6 19:03:48 CST 2020
Mark, I think you need to tell it exactly where to start for your rebase.
Suppose you have 4 commits. You want something like
  git rebase -i HEAD~4
     Matt
On Sun, Dec 6, 2020 at 5:19 PM Mark Adams <mfadams at lbl.gov> wrote:
> When I rebase over master I get conflicts in my files, alas.
> I am thinking I should skip all the conflicts and then fix conflicts in
> the files that I touched and checkout any others from master ... Satish?
> 17:12 1 adams/landau-gpu-assembly *+|REBASE 29/58 ~/petsc$ git status
> # HEAD detached from 3659b78
> # You are currently rebasing branch 'adams/landau-gpu-assembly' on
> '3659b78'.
> #   (fix conflicts and then run "git rebase --continue")
> #   (use "git rebase --skip" to skip this patch)
> #   (use "git rebase --abort" to check out the original branch)
> # Unmerged paths:
> #   (use "git reset HEAD <file>..." to unstage)
> #   (use "git add <file>..." to mark resolution)
> # both modified:      include/petsclandau.h
> # both modified:      src/ts/utils/dmplexlandau/cuda/landaucu.cu
> # both modified:      src/ts/utils/dmplexlandau/kokkos/landau.kokkos.cxx
> # both modified:      src/ts/utils/dmplexlandau/plexland.c
> # both modified:      src/ts/utils/dmplexlandau/tutorials/output/ex1_0.out
> # both modified:      src/ts/utils/dmplexlandau/tutorials/output/ex2_0.out
> On Sun, Dec 6, 2020 at 4:35 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
> wrote:
>> I would first rebase your branch over latest master and then perform your
>> squash. Otherwise you will be squashing other commits which have become
>> part of your branch history (perhaps via updating your branch by
>> intermittently merging, not rebasing, master into it). It seems like that
>> is what is happening right now, although maybe Satish will know better.
>> Best regards,
>> (Jacob Fai - booss - oh - vitch)
>> Cell: (312) 694-3391
>> On Dec 6, 2020, at 15:30, Mark Adams <mfadams at lbl.gov> wrote:
>> This is the status after the first fail. I have nothing to do with these
>> files. There are diffs, but I don't know anything about them.
>> Maybe I should skip failures (lot of them) and then checkout the
>> conflicted files from master, then rebase over master?
>> Thanks,
>> Mark
>> 6:24 1 adams/landau-gpu-assembly *+|REBASE-i 41/76 ~/petsc$ git status
>> -uno
>> # HEAD detached from 564e279
>> '0c5056a'.
>> # Changes to be committed:
>> # new file:   src/snes/tutorials/output/ex19_asm_matconvert.out
>> # Unmerged paths:
>> # both modified:      src/snes/tutorials/ex19.c
>> # Untracked files not listed (use -u option to show untracked files)
>> 16:25 adams/landau-gpu-assembly *+|REBASE-i 41/76 ~/petsc$
>> On Sun, Dec 6, 2020 at 3:48 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
>> wrote:
>>> Mark,
>>> What is the output of git status when it fails? Any files that are
>>> marked staged/uncommitted?
>>> I’ve found that rebase will only work out of the box if your branch
>>> history is completely linear, i.e. no merge commits in between. If there
>>> are merge commits then git is not always able to resolve them. If this is
>>> the case then when the rebase fails at some commit some of the files will
>>> be staged with the changes from both commits that you must __manually__
>>> reconcile.
>>> Best regards,
>>> On Dec 6, 2020, at 14:22, Mark Adams <mfadams at lbl.gov> wrote:
>>> I am doing a rebase -i to squash commits and even if I do nothing git
>>> tris to apply about 7) commits, but starts to fail at #41 and if I try to
>>> --skip it it starts failing on every one. The error message is not very
>>> useful to me:
>>> 15:15 adams/landau-gpu-assembly> ~/petsc$ git rebase -i HEAD~5
>>> error: could not apply a8e4255... Add test of PCASMSetSubMatType with
>>> nonlinear problem
>>> When you have resolved this problem, run "git rebase --continue".
>>> If you prefer to skip this patch, run "git rebase --skip" instead.
>>> To check out the original branch and stop rebasing, run "git rebase
>>> --abort".
>>> Could not apply a8e4255... Add test of PCASMSetSubMatType with nonlinear
>>> problem
>>> Any ideas?  Maybe rebase over master first?
>>> Thanks,
>>> Mark
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201206/2cbee84e/attachment.html>
