[petsc-dev] rebase problem
    Mark Adams
    mfadams at lbl.gov
    Sun Dec  6 16:19:18 CST 2020
When I rebase over master I get conflicts in my files, alas.
I am thinking I should skip all the conflicts and then fix conflicts in the
files that I touched and checkout any others from master ... Satish?
17:12 1 adams/landau-gpu-assembly *+|REBASE 29/58 ~/petsc$ git status
# HEAD detached from 3659b78
# You are currently rebasing branch 'adams/landau-gpu-assembly' on
'3659b78'.
#   (fix conflicts and then run "git rebase --continue")
#   (use "git rebase --skip" to skip this patch)
#   (use "git rebase --abort" to check out the original branch)
# Unmerged paths:
#   (use "git reset HEAD <file>..." to unstage)
#   (use "git add <file>..." to mark resolution)
# both modified:      include/petsclandau.h
# both modified:      src/ts/utils/dmplexlandau/cuda/landaucu.cu
# both modified:      src/ts/utils/dmplexlandau/kokkos/landau.kokkos.cxx
# both modified:      src/ts/utils/dmplexlandau/plexland.c
# both modified:      src/ts/utils/dmplexlandau/tutorials/output/ex1_0.out
# both modified:      src/ts/utils/dmplexlandau/tutorials/output/ex2_0.out
On Sun, Dec 6, 2020 at 4:35 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
wrote:
> I would first rebase your branch over latest master and then perform your
> squash. Otherwise you will be squashing other commits which have become
> part of your branch history (perhaps via updating your branch by
> intermittently merging, not rebasing, master into it). It seems like that
> is what is happening right now, although maybe Satish will know better.
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
> On Dec 6, 2020, at 15:30, Mark Adams <mfadams at lbl.gov> wrote:
> This is the status after the first fail. I have nothing to do with these
> files. There are diffs, but I don't know anything about them.
> Maybe I should skip failures (lot of them) and then checkout the
> conflicted files from master, then rebase over master?
> Thanks,
> Mark
> 6:24 1 adams/landau-gpu-assembly *+|REBASE-i 41/76 ~/petsc$ git status -uno
> # HEAD detached from 564e279
> '0c5056a'.
> # Changes to be committed:
> # new file:   src/snes/tutorials/output/ex19_asm_matconvert.out
> # Unmerged paths:
> # both modified:      src/snes/tutorials/ex19.c
> # Untracked files not listed (use -u option to show untracked files)
> 16:25 adams/landau-gpu-assembly *+|REBASE-i 41/76 ~/petsc$
> On Sun, Dec 6, 2020 at 3:48 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
> wrote:
>> Mark,
>> What is the output of git status when it fails? Any files that are marked
>> staged/uncommitted?
>> I’ve found that rebase will only work out of the box if your branch
>> history is completely linear, i.e. no merge commits in between. If there
>> are merge commits then git is not always able to resolve them. If this is
>> the case then when the rebase fails at some commit some of the files will
>> be staged with the changes from both commits that you must __manually__
>> reconcile.
>> Best regards,
>> On Dec 6, 2020, at 14:22, Mark Adams <mfadams at lbl.gov> wrote:
>> I am doing a rebase -i to squash commits and even if I do nothing git
>> tris to apply about 7) commits, but starts to fail at #41 and if I try to
>> --skip it it starts failing on every one. The error message is not very
>> useful to me:
>> 15:15 adams/landau-gpu-assembly> ~/petsc$ git rebase -i HEAD~5
>> error: could not apply a8e4255... Add test of PCASMSetSubMatType with
>> nonlinear problem
>> When you have resolved this problem, run "git rebase --continue".
>> If you prefer to skip this patch, run "git rebase --skip" instead.
>> To check out the original branch and stop rebasing, run "git rebase
>> --abort".
>> Could not apply a8e4255... Add test of PCASMSetSubMatType with nonlinear
>> problem
>> Any ideas?  Maybe rebase over master first?
>> Thanks,
>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201206/9f738915/attachment.html>
