[petsc-dev] CUDA + OMP make error
Junchao Zhang junchao.zhang at gmail.com
Mon Apr 13 13:54:43 CDT 2020
On Mon, Apr 13, 2020 at 12:06 PM Mark Adams <mfadams at lbl.gov> wrote:
> BTW, I can build on SUMMIT with logging and OMP, apparently. I also seem
> to be able to build with debugging. Both of which are not allowed according
> the the docs. I am puzzled.
 What are "the docs"?
> On Mon, Apr 13, 2020 at 12:05 PM Mark Adams <mfadams at lbl.gov> wrote:
>> I think the problem is that you have to turn off logging with openmp and
>> the (newish) GPU timers did not protect their timers.
>> I don't see a good reason to require logging be turned off with OMP. We
>> could use PETSC_HAVE_THREADSAFETY to protect logs that we care about (eg,
>> in MatSetValues) and as users discover more things that they want to call
>> in an OMP thread block, then tell them to turn logging off and we will fix
>> it when we can.
>> Any thoughts on the idea of letting users keep logging with openmp?
>> On Mon, Apr 13, 2020 at 11:40 AM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> Yes. Looks we need to include petsclog.h. Don't know why OMP
>>> triggered the error.
>>> --Junchao Zhang
>>> On Mon, Apr 13, 2020 at 9:59 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> Should I do an MR to fix this?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200413/ce094508/attachment.html>
