[petsc-dev] CUDA + OMP make error
Mark Adams mfadams at lbl.gov
Mon Apr 13 12:05:33 CDT 2020
BTW, I can build on SUMMIT with logging and OMP, apparently. I also seem to
be able to build with debugging. Both of which are not allowed according
the the docs. I am puzzled.
On Mon, Apr 13, 2020 at 12:05 PM Mark Adams <mfadams at lbl.gov> wrote:
> I think the problem is that you have to turn off logging with openmp and
> the (newish) GPU timers did not protect their timers.
> I don't see a good reason to require logging be turned off with OMP. We
> could use PETSC_HAVE_THREADSAFETY to protect logs that we care about (eg,
> in MatSetValues) and as users discover more things that they want to call
> in an OMP thread block, then tell them to turn logging off and we will fix
> it when we can.
> Any thoughts on the idea of letting users keep logging with openmp?
> On Mon, Apr 13, 2020 at 11:40 AM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> Yes. Looks we need to include petsclog.h. Don't know why OMP
>> triggered the error.
>> --Junchao Zhang
>> On Mon, Apr 13, 2020 at 9:59 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> Should I do an MR to fix this?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200413/44521ddb/attachment.html>
