[petsc-dev] PETSc-3.13.0/Sundials
Antonio Trande anto.trande at gmail.com
Sat Apr 4 09:51:01 CDT 2020
On 04/04/20 16:49, Antonio Trande wrote:
> On 04/04/20 15:29, Jed Brown wrote:
>> Hmm, it's uncharacteristic for this support to be so out of date, but I
>> suspect it will not work at present.  You could try increasing this
>> number and see what breaks.  We'd love a merge request to make that
>> update, even just a start until there is a problem you don't know how to
>> fix.
> Sundials libraries are not recognized.
> See the config.log attached, please.
>> Antonio Trande <anto.trande at gmail.com> writes:
>>> Hi all.
>>> Can anyone tell me if PETSc-3.13.0 and Sundials-5* are compatible?
>>> That's, is it possible compiling petsc with recent Sundials releases by
>>> using the options:
>>>   --with-sundials=1
>>>   --with-sundials-include=/usr/include/openmpi
>>>   --with-sundials-lib=-lsundials_nvecparallel
>>> The file `petsc-3.13.0/config/BuildSystem/config/packages/sundials.py`
>>> reports:
>>>     self.version      = '2.5.0'
>>>     self.maxversion   = '2.5.100000'
>>> so, i presume, it doesn't.
>>> Antonio Trande
>>> Fedora Project
>>> mailto 'sagitter at fedoraproject dot org'
>>> GPG key: 0x7B30EE04E576AA84
>>> GPG key server: https://keys.openpgp.org/
Antonio Trande
Fedora Project
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200404/2aeae340/attachment-0001.zip>
